I recommend using the specs the bolt mfg. gives you in the paperwork. Some guys use a bolt stretch gauge on the rods and some just use the stock specs. If you're using stock rod and main bolts then use the stock specs. Also a lot depends on what lubricant you're using coat the threads. What bolts and lube are you using?
ARP bolts. I didnt think to open the box and read stuff ha... I guess ill see what i find in the box. Im not use to the part coming with any useful information.
