I have posted many forums here, but i did not have the correct engine specs. To those who read this and see that there are a lot of the same questions i am sorry, but i was ignorant when buying a car and i am now left with these problems. I am on a low budget, and do all the work myself. I am 19, living with my parents, and on my way to be an engineer. I do my best to do everything using proper protocol, use the right torque settings, and make sure everything goes together smooth. so...
I bought a 1989 camaro with a rebuilt 350, not knowing anything about timing, carbs, intake, CR, and cam specs. Had all sorts of trouble, but the motor blew up anyhow and i tore it apart to see that it was build like crap.
So i got a 1988 rs, took out the non-running 305 tbi, and put in a motor that my dad had in his garage. It was the only option because of very limited budget.
sbc 350, casting code 3970010
Heads: 462 camel hump, redone with 2.02/1.06 stainless, ported
1.5 roller rockers, dual valve springs
I FINALLY found the cam card after all the other posted saying it was .510 lift with XXX duration.
cam specs: (shocking, but a good explanation for my timing problems)
here we go...
Crane cams 111411, mechanical flat tappet
lift w/1.5 rockers .545" int/.563" ex.
adv. duration 292/300
@ .050 tappet lift 256/264
lsa 105, IC 102, calculated valve overlap to be 86*
valve lash set at .026" while motor is hot.
operating range 4200-7200, oval track cam :spank: :spank: :spank:
I basically have everything set up to match, other than the fact is it my daily driver. I will not lie, i LOVE the top end when i merge on the highway, but stop-go traffic during the day is a pain in the butt!!!
weiand single plane with raise plenum
edelbrock 750cfm, mallory 140 gph fuel pump
short tube headers, dual 2.5" exhaust, goes from headers, to magnaflow mufflers under the driver and passenger seats, and dumps right out
rebuilt rear end with 4.10's and new posi
t-5 5 speed (i'm surprised it has lasted this long
I have a procomp billet aluminum distributor, adjusted my timing to 24 at idle, 38 total.
SO here are my questions:
With these pistons and the 64cc cambers on the heads, what is my static CR? (at the time, i didn't think to take the picture at tdc, so the picture is with the #1 at about 30* ADC)
At 5000ft, (1) will 91 octane be alright??? no pinging at all, and will stay below 190* on the highway. compression test shows 165-170 psi while the engine is warm.
(2) Is pre-ignition audible??? Is it very noticeable???? What are the symptoms???
I was running with no vacuum advance, but it seamed to get a little warm (my collector gaskets have failed twice) I drove for 40 miles on the highway, and at the end of the journey i could hear exhaust leaks from the collectors
(3) What should i limit my vacuum advance to??? (at 3000rpm: 24 initial+ 14 mech+ ???? vacuum= ????) my current vacuum can has 20*, less??? should my total timing be less if my cr is to high??
(4) What should i do about the aftermarket timing tab??? ive heard they can be inaccurate.
Currently i have the idle purposely set at 1200, and still get only 4-5" of vacuum (no leaks... really, have idle mixture screws adjusted)
(5) For the sake of saneness, should i change the manifold??? Ive heard the torker II is good, but i really would like some good input. I know that most people would suggest changing the cam to something sane, but that would be costly, and i really only drive 100 miles a week anyhow (very soon going to get a second car)
please tell if there is something obviously wrong in the above discription, if this motor goes out, i will be left with nothing, and have wasted tons of $$$.
Thanks for the help!!!
here we go...
