I have a 700R4 that i believe is from an astro van which would make it a V6 trans. I was told it worked fine except it had no overdrive. First off, what would cause it to have a problem with just overdrive and nothing else?
Second. What would it take to make a 700r4 capable of handling a stock or almost stock 700R4 in a 79 Chevy truck with a 454 and 4.10 gears? It will need to be CAPABLE of towing 7 or 8 thousand pounds. My work trailer does not weigh that but it might by the time i get done with it. This truck will only be used as a backup truck in case my other truck breaks down. I cannot afford to be down. The truck may be used to haul some light stuff from time to time or be driven around town empty some (this is part of the reason for the 4.10s and the 700r4[overdrive], that and the 3.06 first gear) I could just use a 4L80E but that gets expensive FAST. I think a 700r4 with corvette parts and additional clutches and a large transmission cooler would do the job.
What do you guys think of this and what exactly do I need to have done? Transmissions aren't my specialty...
