My project vehicle has a 700r4. When the driveshaft was made up the first shop didn't do a very good job welding one end. The second shop fixed it but the total length ended up 1/2" shorter than what I initially wanted. The slip sleeve will go in 4 1/2" if slid in all the way. Once installed it's pulled back 3" to bolt it at the rear, leaving 1 1/2" engaged. Is this too little engagement??
Second problem. I noticed a puddle of tranny fluid below it today. It appears to be dripping from the front u-joint. The rear seal area appears to be dry. Is it possible for it to be leaking down the centre of the slip yoke?? When I unbolted it at the rear and shoved it into the tranny, fluid gushed out at the u-joint. The yoke supposedly came from an Astro van that was equipped with a 700r4.
