I have a 62 Pontiac Stratochief(similar to a Bonneville) that came with a SBC coupled to a powerglide. I will be swapping in a mildly modified big block Chevy for more torque, since this is a fairly heavy car. I was thinking of installing a 700R4 to replace the PG since it has an overdrive gear, therefore I could go with a fairly low ratio rear end and retain some decent gas mileage on the highway. My question is, I would like to retain a stock appearance both inside and out, can the stock column shifter work with this tranny, since the PG is a two speed and the 700R4 is a four speed? Would I be able to manually shift through all the gears? Maybe there is a custom bellcrank that would alow this?
