How much fluid to fill a 700R4 tranny? ALSO, when I pull my drive line completely out, how much fluid will I loose? Thanks again, Dana
It just takes time and money
Type: Automatic four-speed overdrive with torque converter clutch.
Gear Ratios: 1st-3.06, 2nd-1.63, 3rd-1.00, 4th-0.70, Reverse-2.29
Converter Diameter: 298mm (11.7 inches)
Converter Stall Torque Ratio: 1.91
Maximum Engine Speed: 6250 RPM
Maximum Towing Capacity: 7000 lbs.
Maximum Gross Weight: 8600 lbs.
Fluid Capacity: 11 qts. approx. (dry)
(Refer to service manual for complete instructions on fluid fill capacity.)
Fluid Type: Dextron III
Weight (with converter): 164 lbs. (dry), 184 lbs. (wet)
Shift Quadrant: P, R, N, D, 3, 2, 1
from http://www.transmissioncenter.net/700r4.htm
Leakage from the transmission shaft should be minimal, if you drop the pan. I put a cap over the output shaft and cover it with a baggie.
Premium Member
Even if you do not drop the pan the leakage shoudl be minimal. You can always jack up the rear a bit higher than the front to help against gravity doing its work.
