blue85350 said:
apparently, my little brother was looking at it when i came home from work, ticked off that it drained 2 qts. in a day, and came in to tell me that. yeah open hole(sorry if i sound like an ***, but i'm on my second case of trans fluid in the last 2 weeks) anyway thanks to everyone for the help and suggestions
It is interesting on how the instructor tells you the cable is unneeded , so you leave a 3/8 inch hole open on the tranny case.
We had a customer
go off on our counter help this past summer.... calling every body names , " I am gonna get a lawyer threat" ... all over a leaky 700r4 tranny, no shifts till high RPM....The kid had called our tech guy several times.
When we got his car on the lift , the filler tube was stuck in the case of the 700r4.... there was
NO rubber sealing sleeve on the filler tube. The
un-hooked TV cable was resting on the header ( melted).
The kid's dad called me a G-D liar when I explained the TV cable must be hooked up. I walked away & let the shop manager handle it.
Good luck with your car, you will get it done. It is just a large learning curve
