Re: sscamero,
red65mustang said:
for street wars, it's all about the rear gears, and jakeshoe needs to know your gears to assist you if your gona attempt a shift kit
a shift kit with high gears (2.8?) will make your car slower because the engine rpm drops to much when it shifts
you can get a screw adjustable vacuum modulator ($40? don't do Chevy) which allows you to adjust/change at what rpm it does shift to work with your gears (wish Ford had one!). Easy to swap/bolt in.
serious race car on a trailer....gotta have a shift kit
street car...as jakeshoe said, there is a risk the tranny will break
Gears have nothing to do with shift kit selection.
You will choose a shift kit base don your desires fro how hard a trans will shift, power output, etc..
A shift kit will NOT make your car slower under ANY circumstance if it is properly designed, rear gear or otherwise.
Engine RPM drop will be identical.
A trans with a 2.52 1st gear ratio, and a 1.52 2nd ratio will drop the same amount of rpm on a gear change, given the same variables such as converter.
a highway gear MAY cause the trans to feel like it shifts harder, as well as a tight converter, short sidewall tires. However it is a "feel" thing caused by the variables, not by the internal workings of the trans.
The main effect of a shift kit is to speed the apply of a clutch pack for a firmer feel.
Let's use a Th350 for an example.
When it shifts from 2nd to 3rd, it only has to apply the 3rd or direct cltuch pack.
The faster you apply, the firmer the shift is going to be.
Block the 2-3 accumulatorm dril the feed hole, and leave out all the cushion plates, and BANG, it will shift hard to 3rd.
Parts breakage is caused by an improperly calibrated kit, that bypasses critical shift timing controlled by the accumulators.
This is why you want to be sure your chosen kit doesn't cause harm.
Ever hear of a broken intermediate sprag in a TH350 or 400... that is caused by improper shift timing, or improper burnout technique.
Adjsutable modulators have little effect, and are mostly for part throttle shift control.
As stated,
A well designed kit will include mods to increase the life of the trans even in mild street applications. Such as dual feeding the direct clutches.
