I think I blew a trans vent tube from my 350 t at the track on the 3rd pass. There is just a 3/8 size hole at the top of the driver side of the unit. Enough fluid came out that the tires spun and they had to clean the track, sorry. Could a muddopper get in stop up the vent causing the internal pressure to blow the hole tube and all?
Bee's under the Bonnet...
Doc here :pimp:
I find it unlikely the vent would blow out before a Bee Nest.
Also, Bee's by nature Don't like petroleum products...(they can't Breathe So awfully swell around the stuff...and BTW, WD~40 is similar in Make up to RAID...spray some in you hand of both, and smell it, you can't tell the difference...)
Replace the vent, and cut some window screen and fit around the vent in a " BUBBLE" about 2 inches in diameter, secure it with a tie wrap, and spray it down with WD~40, if you really feel you have Bee's under the Bonnet...
I'd look for other sources of high pressure.
Doc :pimp:
theres suppose to be a vent with a top on it so nothing can get in.i'd think that something inside plugged up and blew.
got down track and thought you had a funny car huh!!
i'm sorry i couldn't resist.good luck
