hey guys i bought a new aluminum transmission deep pan and autometer gauge and i was wondering what size NPT tap and drill bit should i use to drill and tap the pan for the gauge fitting. thanks for your replies.
NO!.... You have a 1/8 NPT. The tap drill is a letter drill "R". Be sure to check the size BEFORE you drill. I am 99% sure of the size.gm_71chevelle said:well i figured out its 3/8 so i read you should use a 9/16 drill bit and then tap it with a 3/8 NPT tap right? i just dont want to mess this pan up
Take the fitting to the store and match it to a tap. BE SURE!gm_71chevelle said:well my gauge mechanical and i read somewhere that they are 3/8 and that 1/8 is electrical. thanks
