Hi everybody, some background for you:
64 Thunderbird, Cruise-O-Matic MX transmission, 81,000 miles all city driving, sat in storage from 1994 until spring 2020. Transmission has never been rebuilt.
It did not drive much in 2020 due to various other issues, but after working out the kinks I've driven it about 500 miles this summer and fall with no issues (except leaks) until recently. It has leaked about 2.5 qt in the 500 miles, but only seems to leak after sitting in the garage for a while. It doesn't leak when sitting on the driveway for several hours if I wash or work on the bird.
Previous work:
2020:
Upon getting it running, it went into gear and drove ok with the old fluid, so I changed the fluid. Still worked good.
Developed rough shifts.
Found vacuum modulator had bad diaphragm
Replaced modulator
All good.
2021:
Worked out other problems and then drove the thing. Added fluid as necessary.
Currently:
It is slow shifting into high gear intermittently upon acceleration to highway speeds. By "slow" I mean slow to decide it wants to shift. When it does shift, it shifts normally, just at a higher speed than normal. It has done this 3 times in the last 75 or so miles. Other times completely normal.
Still leaks like a sieve.
The current plan:
Is there anything else I should do while the pan is dropped?
Options:
Now we enter a bit into speculation for now. I will post more when I get to work on it.
I know for sure I can get a seal kit through a reliable source if I decide to go that route.
This place appears to have a rebuild kit:
https://www.rigidaxle.com/products/...um-automatic-transmission-master-overhaul-kit
A C6 swap has been done on 64 Tbirds before. From what I read on Thunderbird forums, it requires modification to shift linkage, crossmember, and a driveshaft. Doable, but I'd rather not mess around with that for at least another 2-3 years when I'm out of college and want to build the 390.
Any other options?
Other initial thoughts?
Thoughts on whether or not a guy who's never been into a transmission before could rebuild it right the first time by himself?
I'm more of an if it ain't broke don't fix it guy (but still believe preventative maintenance has its place) so even if it looks bad when I drop the pan, I will likely just not beat on it and drive it until it drops. I don't have a lot of time on my hands with school (read: almost no time), so I'll probably take my chances.
Again, I will be sure to post details later when I drop the pan so we can address the situation more directly.
Thanks for your responses as always.
Previous work:
2020:
Replaced modulator
All good.
2021:
Currently:
The current plan:
- Change filter and fluid.
- See how bad it looks in the pan.
Options:
- If it looks good enough as far as shavings and friction material, I put it back together with new filter and forget it.
- If it's bad I may still slap it back together for now, but know its days are numbered...
Any other options?
