1 - 10 of 10 Posts
no
i think my brother tried it when we were younger and broke; and it didn't work. the engine oil doesn't have the frictional viscous properties and just foams up and wont continuosly drive the trans.
you can add a quart or 2 to a tranny if it has morning sickness.
Sometimes it helps, some times it don't
using ALL engine oil in a tranny is not advised
:welcome: we had a allison tras. rebuilt a the local detroit dealer and they recomended using motor oil insted of trans. fluid,they have found out that motor oil will hold up better than dexron under extreme duty,handles heat better, we tryed it and been working flawlessly since the rebuild.used straight 40 w with three bottles of lucas trans mix. it locks hard ,shifts perfect, operating temp went down 15%.we realy hammer on these things hard.it was just a thought reason why i was asking.
======= that is how I learned to use engine oil in a weak tranny with hard internal seals.... a geezer that built Allisons told me about it years ago
1 - 10 of 10 Posts
