1 - 8 of 8 Posts
I have a Tremic T-5 in my Ford Model-A hot rod. It came from a 1995 Mustang GT with a 302 V-8. I had it rebuilt by a racing transmission shop. They advised me to use ATF. Someone please tell me how to fill the trans and how do I tell when it is filled (but not overfilled).
Thanks in advance.
Buzz (MoonBat)
High Performance Rear Ends
There is a fill plug on the right side of the transmission. Fill it until the fluid is at the bottom of the hole. There is a stud on the left side of the transmission that people often mistake for the fill plug. It's actually the pivot for the 5th gear shift linkage. If you remove it you will have to disassemble the transmission to get it back in.
1 - 8 of 8 Posts
