Rather than rehash everything here, this link will bring you "up to speed" to the point I'm at now... the pertinant info is on page two of this thread... (edit: skip down two posts for the info contained in the link below)
http://www.webrodder.com/forum/viewtopic.php?t=85
Thank you in advance if you bothered to read that. Now my question is this:
In order to get the upper bars to fit in the available space, I'll have to cut them from their original length of 14.5" to 10.5" (eye-to-eye). Is that too much of a change and is pinion angle delta the only concern? Is 4-5 degrees too much delta through full suspension travel? I don't mind cutting the bars and retapping them but I want to be sure it's the right thing to do. BTW, the lower bars are 18" long.
TIA,
Richard
TIA,
Richard
