well as some of you may know (if you remember me lol) i was going to build a 12 bolt for my elky then i couldnt because the cylinder heads need a lot of work (worn guides now bad springs) i might as well buy new heads. anyway its gone back and forth rear end or heads rear end or heads. im still trying to figure that out so im just shopping for both right now because they both need to be done asap.
anyways i have been looking at a set of RHS heads for 990 (a pair) but then i came across aluminum heads are only a 100 or 200 more (if i dont go all out performance that is) i came across a set of Trick Flow super23 heads for 1099
http://www.summitracing.com/parts/TFS-30400002/
i was wondering what you all could tell me about these heads. ive read they out flow many other heads of equal size. but i dont know what the "perks" are to the twisted wedge design.
and is it true with aluminum heads you can run .5 CR higher on the same octane gas and not risk denotation? and how much lighter are aluminum heads they cast iron?
this is my setup
383 10.25CR
currently 63cc iron heads cast #3947041
650cfm carb
268h cam
street fire HEI dist
victor water pump
rpm air gap intake
hooker comp headers
and i run 91 octane gas
this is my setup
383 10.25CR
650cfm carb
268h cam
victor water pump
rpm air gap intake
hooker comp headers
