The question is what are you planning on doing with the truck when it is lightened? Why your looking for weight reduction? Use it as a drag car? Save some gas?
How many of the luxuries can you live with out, heat, ac, radio, sound deadener, power windows, spare tire and jack, if rain is no concern...inner fenders, install fiberglass hood/fenders/tailgate/roll pan, light weight seat(s), etc.
Heater removed. Ac gone as well, except for the compressor (using it as a pulley for the stock serpentine setup). The radio will stay. The spare tire and jack are gone. The power windows might go if I find some interior door panels or whole doors. Roll pan is in the works. I guess I just have to look and see what I can do without.
Pull the A/C compressor and measure for a shorter belt. Pull the compressor bracket as well.
Any creature comforts you can do without...do without 'em. The tailgate is heavy and easy enough to remove. Pull the rear bumper and install a roll pan. Spare tire and mounting method can go.
After that, it's just putting holes in sheetmetal and losing what you can afford to lose. Inner fenders, inner bedsides/floor....stuff like that.
Other ways....change factory intake and heads out for aluminum versions. Better performance due to head design, along with significant decrease in weight.
1 - 6 of 6 Posts
