I'm not sure of the true correct techincal term is,.... "oil-canning" is what I call it..... When you push on the metal and it goes 'Bloop-Bloop', in and out like an old oil can.
Obvoiusly you can't bondo over this because the highs go to lows and vice versa. How can I firm up the metal ?
I don't have a shrinking disc, it sounds like it may do the trick. Not sure though. will it?
I do have a Stud welder for pulling dents...will this work? if so, do I stud weld the Highs? or Lows?
For reference. This is old Subaru van I am restoring. The Asian factory metal is very thin, probably 22 ga. ( unlike thick metal USA cars ) This "oil-canning" problem is in only in a couple of spots, { thank goodness } , one spot had prior accident damage repirs on the pass. door, about 6" dia. , I can sort of get behind it....but, not real easily.
The other spot is the tailgate. Impossible to get behind.
Both spots are very visible.
I'm nearing the end of my body work, but I've left these spots till the last trying to figure out how to deal with them.
Thanks,
Mark
Thanks,
Mark
