Tubing Bender Fabrication Guide - Hot Rod Tech - Hotrodders Knowledge Base
235 Views 0 Replies 1 Participant Last post by  VS-Admin
12-31-1969 07:00 PM
URL:http://www.blindchickenracing.com/Tools/Tube%20Bender/Tubingbender.htm
Description:Pictorial guide to fabricating a pipe tubing bender. Parts needed include 120 degree, 1.5" diameter X 7" radius die set, plus roller w/Teflon impregnated bushings and a 1" diameter pivot shaft. Guide includes framework dimensions, type of jack needed and fabrication for the spring mounts.
Category:Metalworking
Tags:None
User: Guest
Send to Friend
1 - 1 of 1 Posts
1 - 1 of 1 Posts
