OK I'll chime in here and throw out my $.02.
Problem with getting a used turbo is just that, it's used. More than likely you are looking at rebuilding it anyway, which depending on the turbo, might cost you a couple hundred dollars just for the rebuild kit. Unless you have rebuilt them before they can be a bit tricky and since they spool at such high rates, tolerances and specs are vital to the life of the unit. Many turbos, especially older KKK, and Garrett's are designed with a 30,000 mile life span. So the odss of getting one of these that does not need to be rebuilt are slim to none. No shaft play, and free spinning wheels do not equal a bolt on and go turbo.
I do not, and I must say this, have any experience what-so-ever turbocharging V8's. Porsches yes, Chevys no. Basics are the same but configuration and desired compressors are vastly different. If you are serious about optimizing the use of a turbo (or 2) you should invest in something like Turbo Calculator, which will give you a very good idea of what would be ideal for your particular engine etc.
There are many ways around just buying a bolt on kit, but in my opinion, unless you are into trial and error engineering, you are better off just going with a proven winner. Ask most ricers and they will eventually agree that blowing motors is common place when trying to work out your own system.
