Hello, I am very new to this site. A friend told me this was the place to go to get good help. I want to install a single turbo on a G-Body which has a SBC 350. I am very fimilar with turbos and requirements need for one to work properly. However they have all be factory turbo cars. I have never actually installed one from scratch. I am having a hard time figuring out how to route the exhaust piping? I was trying to find some pictures on the net but I was not lucky. I did notice on E-BAy there were some twin turbo headers but I want to keep the Air condition and I was looking for a single turbo set-up. If possible I was thinking maybe I can use the headers on the car now and make that work but I am at a loss for the design. Is there someone here who can help? Any info in the right direction in much appreciated.
Listen and Learn
I have looked into turbo headers for sbc and not too many single turbo setups out there. I am sure they are out there but hard to find. I was gonna use stock manifolds and the crossover pipe because its small diameter=more back pressure and mount it backwards. Then cut off the section right after they join and weld up a t3/t4 flange. Much more fabricating will be needed depending on how much room you have but you get the idea. I always thought each header had to be equal length to the turbo so you have the same back pressure on each side but all the kits i have seen have different lengths so i guess not.
