1 - 2 of 2 Posts
well my wipers and turn signals in my '86 camaro simultaneously stopped working, my wipers may work for a short time when i replace the fuse that it blows, but then it blows within a few minutes, my blinkers however stopped working and haven't worked since, i have a hunch that there is a short in the steering column where the wiring for both are located, but if I were to take apart my steering column then what? the rainy season is coming in and the cops are roaming as school is back in, so driving my car is getting to be more of a hassle than I'd like, any suggestions?
Wipers
More than likely you will find the wiper pivot switch is bad, even more so with a tilt wheel. The wires are probably pinched thru. Your car may come as a 1 piece unit a "Multi-function" Lever GM calls it. And it's not cheap. We just put one in our Tahoe and the part was $200.00. Good Luck.....:smash:
1 - 2 of 2 Posts
