I am looking at new 9" Ford rear end housings. There are centered housings and pinion centered housings. The offset is 2 inches. My drive shaft is 30 ". The vertical u joint working angle is a little less than 3 degrees. On the high end, but within the recommended "no more than 3.5" that I have always lived by. If I offset the pinion 2" in 30 " I get about 4.7 degrees for the sideways angle. I did this by using a 30" straight edge flat on the table, raising one end 2" and measuring the angle with my digital angle finder. (I can't do the math anymore. Been too long.
I get 4.7 degrees. I sure would like to have the centered housing, but I don't want to have U-joints wearing out either. 4.7 looks like to much to me. I'm not really sure on how the compound angles figure into this though.
Any of you guys running offset pinions with relatively short driveshafts?
I think I am going to have to bite the bullet and go with the offset housing. It looks funny from the rear.
What do you think?
What do you think?
