I put one of these Universal Stop Light Switches on my hotrod. It originaly had an inline pressure switch. I eliminated it and extended the wiring up to the Universal Stop Light Switch as seen in the picture.
It worked perfectly for about 8 months....but today while doing other work on the car I smelled something burning and smoke was coming from the area where the wiring hooked to the Universal Stop Light Switch.
I disconnected the battery and of course the smoke and smell disappered.
I unplugged the two wires to the switch and hooked the battery back up with the wires unplugged from the switch and the wires showed no evidence of heat or smoke.
I hooked the wires to the switch and connected the battery back up and the wires were getting warm again, so I unplugged them.
This switch says it is rated at 42 Amp max. What does that actually mean? Did I do something wrong by just extending the wires from the pressure switch to the front of the vehicle and plug them into this Universal Switch?
OR....is it a defective China made switch and I can just replace the switch and everything will be OK?
I thank you in advance for your input on this subject.
