1 - 7 of 7 Posts
Hello,
I'm in the process of installing a triangulated 4 link on my 48 Chevy. For the upper rear shock mount bar I was hoping to repurpose either a solid steel bar that came off my truck (pic attached), or an old barbell I had in my basement.
I'm not really sure what it's old purpose was as it was not connected to anything on the frame.
Does anyone with more experience see any issues with using either of these items?
Thanks,
-A
Gotta love a turbo!
Just keep in mind, if you use coilover shocks the entire (rear) weight of the car is handled by whatever you use for the mount bar.
Russ
WFO
I'd use a piece of rectangular mild steel tubing instead of trying to use a sway bar. Couldn't cost $20 for what you need. If you decide to weld on the sway bar be sure the welds are done right. At least for use as a sway bar the welds are critical, and to be avoided if at all possible. Might not be such an issue using a sway bar as a cross member, but still... just saying.
I wouldn't use round stock unless the quality is known.
If your top shock mount is a single pin I'd weld in a boxed plate with a hole on the top tab. If it's a crossbolt, I;d weld a pair of tabs to the tubular crossmember, and drill for a crossbolt. I wouldn't bolt through the tubing, or drill the tubing, as it will weaken the tube.
1 - 7 of 7 Posts
