I thought I'd post my first try at leading since there are often inquiries about filling small holes etc.
I bought body solder, tallow, tinning butter and a paddle. After cleaning and sanding a my sheet metal that had a patch panel recently welded in, I put a light coating of tinning butter on and heated the area gently with a regular propane torch. Not a lot of heat is required. The tinning butter eventually melts and fuzes a tin coating to the metal. A quick wipe with a clean rag improves the tin finish and wipes away any residue. Simply reheating the metal and applying a rod of body solder gave me excellent results. Super adheasion. After building the area up I ground it flush and level with a body sander.
The 2 skills you'll have to master are proper cleaning and tinning and working against gravity. Areas that cannot be cleaned and/or tinned will not accept solder, although you can possibly bridge the area if it is small. To deal with gravity, if it's a vertical surface, do not over heat the solder. Heat it to a "slush" consistancy and move it with the paddle just licking the area with heat from time to time. Too hot and it will simply run off.
There are very few things that I've been 100% pleased with the results the first time I tried it. This is the exception. Other than the solder being a slightly different shade of gray, you can't see the repair. A skill anyone can learn.
Keith
Keith
