Kinda long title, but just wondering.
I have a set of 16 L9 stover lock nuts to convert my press in positive stop studs to be adjustable on my 74 351W, wondering if i could run the old rocker arm balls (replaced old rocker arms with comp magnum arm kit) inverted as thick washers instead of stacking a bunch of grade 8 washers (which i already have) or what kind of washers i could get that would be thick and heat treated as i'm assuming the rocker arm balls are. Or will grade 8 washers stacked be sufficient?
thanks a bunch
Dubz
thanks a bunch
Dubz
