anyone have any suggestions as to the ease of swapping a flathead v-8 into a 1953 Chevy 1 ton?
A 3 speed overdrive tranny is available with a running mercury motor. Current transmission is a sm420 4 speed and the rear is a stock 5.14 but supposedly can be swapped for a 4.10 out of a 3/4 ton Chevy 67-72.
Anyone done this or know the ratios of a 50's ford 3 speed with overdrive?
Any pros or cons on this will be welcome. The motor currently in the truck is a Chevy 235 that I unstuck by dragging the truck in high gear. this was before I heard you should spray something down the spark plug holes and work the engine free _gently_
ain:
