Hey- I'm working on an 85 S10 ext cab v8 project. I'm dropping in a nice gen 1 350, and have a th350 to run behind it- but I'm contemplating an overdrive, or 5/6 speed swap (the truck was originally a manual, so all the provisions are there for that swap) My question is about the split drive shaft...
How much torque will that 2 piece drive shaft handle? And- if I were to shorten the drive shaft for an overdrive trans swap or t56, would it be better to shorten the front section or rear section??
Does anyone know if that split d/s would be balanced enough for a t56's low gear ratios?
Would it be feasible to swap the two piece d/s with a single d/s, if I installed a longer trans? I'm sure that using the two piece would require moving crossmembers/ carrier bearings to align the drivetrain geometry, so I just thought it may be easier to go with a longer, single shaft.
Any input would be appreciated! Thanks guys!
Nooj
Nooj
