1 - 7 of 7 Posts
84 Mutt
How much (in timing terms) does the vac. advance, (non-adjustable) advance the timing( in degrees)?
I've heard that on top of your total timing , the vac. adv. adds a little more to the total.
:rolleyes:
It varies with year and application, ive seen canisters stamped from 10-20 deg, BBC'S (early ones that is) seem to use less than sm blocks.
U having probs with part throttle pinging too?
Cheers RobbieRat
84 Mutt
Discussion Starter #3
yes sometimes...Ive been doing spring combos to get the curve to fit my app. Actually pinged at 3000 , hard acceleration. Had some detonating going on. I am wondering if im not talking the vac. advance into consideration.I just set up the mech. advance to open quickest and is set to 18*which should be at full advance at 1800 -2000 rpm.( right around stall speed). Dat good?
84 Mutt
Discussion Starter #5
Very helpful page. I understand (in general) how all that crap works now. I'm sure this relates to chevy blocks too ,no?
Anyway thanks much..!!:thumbup:
1 - 7 of 7 Posts
