1 - 15 of 15 Posts
CLICK ON MY AVATAR
I'm trying to time my sbc 350.My hei has vacuum advance.With the vacuum hooked up my initial timing is at 14*.When I pull off the vacuum hose it still at 14*.Is this right?I thought with it hooked up its supposed to read differently then when unhooked(timing)I have the vacuum hose running to the ported vacuum line on my edelbrock 1405 performer 600cfm carb.What is the full time vacuum port for?Please help!!!Just learning
"May the Schwartz be with you"
Ported vacuum will not have vacuum at idle. The port starts drawing vacuum as the carb is opened (engine running of course).
You must be confusing it with manifold vacuum that loses vacuum as you put the engine under load.
You are correct to hook the advance to ported vacuum.
What is your engine set-up?
Which is better ported vacuum or manifold vacuum has been debated alot if you do a search I'm sure you will come up with lots of info. I personally run my engines on manifold vacuum with great success (and a smoother idle too).
It would depend on the engine though. Unless you run the lightest springs for the mechanical advance, the vacuum advance would actually retard the timing every time you got on it. For most engines this isn't good. There are exceptions to the rule however.
I too run my vacuum advance off the manifold port. It does depend in the cam you are running though. With a fairly radical cam with low idle vacuum you are better off running vacuum off the manifold port. This will advance the timing at idle which will allow you to back off the base idle screw and actually maintain idle on the idle circuit. When the throttle is depress the throttle the timing will back off due to the drop in vacuum and will minimize detonation.
Steve
Steve
That is exactly what I was getting at.
We need to know what he has to give correct info. to help him however.
CLICK ON MY AVATAR
as far as I know its a stock goodwrench 1994 350 crate motor,cast iron heads,not sure about the cam,can't hear that lopey cam sound so i would think its pretty basic.I just got this car...I don't know too much about it except what I've described.it has 350 turbo trans,rams horn manifold.edelbrockperformer 600 cfm carb.you guys are starting to confuse me??
Stay with the ported vacuum.
Unplug it, block the vacuum port and set initial timing to 8 deg.
Let us know how that works.
CLICK ON MY AVATAR
Discussion Starter · #9 ·
why 8 degrees? I was told by a couple different people to set it at 14*. Is 14 degrees too high? Can some other folks chime in here? Thanks bm
PS Thanks for being patient and answering all my stupid questions!!!....In high school I took wood shop insted of auto shop.....Now I'm a general contractor...I sure do wish I would have taken auto shop because I love cars!!!
On that engine I see absolutely no reason to run that much initial.
Try the 8 and let us know.
Also, did you get a spec book with the engine?
By the way, I am a GC also.
CLICK ON MY AVATAR
Discussion Starter · #11 · (Edited)
Lonestar,
No spec book with the motor.I found a great article on vacuum advance written by a gm engineer.Its really long but explains alot......This article was originally posted at Camaros.net by JohnZ, a former GM engineer.
As many of you are aware, timing and vacuum advance is one of my favorite subjects, as I was involved in the development of some of those systems in my GM days and I understand it. Many people don't, as there has been very little written about it anywhere that makes sense, and as a result, a lot of folks are under the misunderstanding that vacuum advance somehow compromises performance. Nothing could be further from the truth. I finally sat down the other day and wrote up a primer on the subject, with the objective of helping more folks to understand vacuum advance and how it works together with initial timing and centrifugal advance to optimize all-around operation and performance. I have this as a Word document if anyone wants it sent to them - I've cut-and-pasted it here; it's long, but hopefully it's also informative.
TIMING AND VACUUM ADVANCE 101
The most important concept to understand is that lean mixtures, such as at idle and steady highway cruise, take longer to burn than rich mixtures; idle in particular, as idle mixture is affected by exhaust gas dilution. This requires that lean mixtures have "the fire lit" earlier in the compression cycle (spark timing advanced), allowing more burn time so that peak cylinder pressure is reached just after TDC for peak efficiency and reduced exhaust gas temperature (wasted combustion energy). Rich mixtures, on the other hand, burn faster than lean mixtures, so they need to have "the fire lit" later in the compression cycle (spark timing retarded slightly) so maximum cylinder pressure is still achieved at the same point after TDC as with the lean mixture, for maximum efficiency.
The centrifugal advance system in a distributor advances spark timing purely as a function of engine rpm (irrespective of engine load or operating conditions), with the amount of advance and the rate at which it comes in determined by the weights and springs on top of the autocam mechanism. The amount of advance added by the distributor, combined with initial static timing, is "total timing" (i.e., the 34-36 degrees at high rpm that most SBC's like). Vacuum advance has absolutely nothing to do with total timing or performance, as when the throttle is opened, manifold vacuum drops essentially to zero, and the vacuum advance drops out entirely; it has no part in the "total timing" equation.
At idle, the engine needs additional spark advance in order to fire that lean, diluted mixture earlier in order to develop maximum cylinder pressure at the proper point, so the vacuum advance can (connected to manifold vacuum, not "ported" vacuum - more on that aberration later) is activated by the high manifold vacuum, and adds about 15 degrees of spark advance, on top of the initial static timing setting (i.e., if your static timing is at 10 degrees, at idle it's actually around 25 degrees with the vacuum advance connected). The same thing occurs at steady-state highway cruise; the mixture is lean, takes longer to burn, the load on the engine is low, the manifold vacuum is high, so the vacuum advance is again deployed, and if you had a timing light set up so you could see the balancer as you were going down the highway, you'd see about 50 degrees advance (10 degrees initial, 20-25 degrees from the centrifugal advance, and 15 degrees from the vacuum advance) at steady-state cruise (it only takes about 40 horsepower to cruise at 50mph).
When you accelerate, the mixture is instantly enriched (by the accelerator pump, power valve, etc.), burns faster, doesn't need the additional spark advance, and when the throttle plates open, manifold vacuum drops, and the vacuum advance can returns to zero, retarding the spark timing back to what is provided by the initial static timing plus the centrifugal advance provided by the distributor at that engine rpm; the vacuum advance doesn't come back into play until you back off the gas and manifold vacuum increases again as you return to steady-state cruise, when the mixture again becomes lean.
The key difference is that centrifugal advance (in the distributor autocam via weights and springs) is purely rpm-sensitive; nothing changes it except changes in rpm. Vacuum advance, on the other hand, responds to engine load and rapidly-changing operating conditions, providing the correct degree of spark advance at any point in time based on engine load, to deal with both lean and rich mixture conditions. By today's terms, this was a relatively crude mechanical system, but it did a good job of optimizing engine efficiency, throttle response, fuel economy, and idle cooling, with absolutely ZERO effect on wide-open throttle performance, as vacuum advance is inoperative under wide-open throttle conditions. In modern cars with computerized engine controllers, all those sensors and the controller change both mixture and spark timing 50 to 100 times per second, and we don't even HAVE a distributor any more - it's all electronic.
Now, to the widely-misunderstood manifold-vs.-ported vacuum aberration. After 30-40 years of controlling vacuum advance with full manifold vacuum, along came emissions requirements, years before catalytic converter technology had been developed, and all manner of crude band-aid systems were developed to try and reduce hydrocarbons and oxides of nitrogen in the exhaust stream. One of these band-aids was "ported spark", which moved the vacuum pickup orifice in the carburetor venturi from below the throttle plate (where it was exposed to full manifold vacuum at idle) to above the throttle plate, where it saw no manifold vacuum at all at idle. This meant the vacuum advance was inoperative at idle (retarding spark timing from its optimum value), and these applications also had VERY low initial static timing (usually 4 degrees or less, and some actually were set at 2 degrees AFTER TDC). This was done in order to increase exhaust gas temperature (due to "lighting the fire late") to improve the effectiveness of the "afterburning" of hydrocarbons by the air injected into the exhaust manifolds by the A.I.R. system; as a result, these engines ran like crap, and an enormous amount of wasted heat energy was transferred through the exhaust port walls into the coolant, causing them to run hot at idle - cylinder pressure fell off, engine temperatures went up, combustion efficiency went down the drain, and fuel economy went down with it.
If you look at the centrifugal advance calibrations for these "ported spark, late-timed" engines, you'll see that instead of having 20 degrees of advance, they had up to 34 degrees of advance in the distributor, in order to get back to the 34-36 degrees "total timing" at high rpm wide-open throttle to get some of the performance back. The vacuum advance still worked at steady-state highway cruise (lean mixture = low emissions), but it was inoperative at idle, which caused all manner of problems - "ported vacuum" was strictly an early, pre-converter crude emissions strategy, and nothing more.
What about the Harry high-school non-vacuum advance polished billet "whizbang" distributors you see in the Summit and Jeg's catalogs? They're JUNK on a street-driven car, but some people keep buying them because they're "race car" parts, so they must be "good for my car" - they're NOT. "Race cars" run at wide-open throttle, rich mixture, full load, and high rpm all the time, so they don't need a system (vacuum advance) to deal with the full range of driving conditions encountered in street operation. Anyone driving a street-driven car without manifold-connected vacuum advance is sacrificing idle cooling, throttle response, engine efficiency, and fuel economy, probably because they don't understand what vacuum advance is, how it works, and what it's for - there are lots of long-time experienced "mechanics" who don't understand the principles and operation of vacuum advance either, so they're not alone.
Vacuum advance calibrations are different between stock engines and modified engines, especially if you have a lot of cam and have relatively low manifold vacuum at idle. Most stock vacuum advance cans aren’t fully-deployed until they see about 15” Hg. Manifold vacuum, so those cans don’t work very well on a modified engine; with less than 15” Hg. at a rough idle, the stock can will “dither” in and out in response to the rapidly-changing manifold vacuum, constantly varying the amount of vacuum advance, which creates an unstable idle. Modified engines with more cam that generate less than 15” Hg. of vacuum at idle need a vacuum advance can that’s fully-deployed at least 1”, preferably 2” of vacuum less than idle vacuum level so idle advance is solid and stable; the Echlin #VC-1810 advance can (about $10 at NAPA) provides the same amount of advance as the stock can (15 degrees), but is fully-deployed at only 8” of vacuum, so there is no variation in idle timing even with a stout cam.
For peak engine performance, driveability, idle cooling and efficiency in a street-driven car, you need vacuum advance, connected to full manifold vacuum. Absolutely. Positively. Don't ask Summit or Jeg's about it – they don’t understand it, they're on commission, and they want to sell "race car" parts.
It gives me great pleasure indeed to see the
lonestar,
so I set my initial timing to 8*like you said and I have water or someting pouring(not really pouring kinda spraying) out of my tail pipes?/What is this?It kinda sounded better at 14*.I need some input here.This is driving me crazy!BM
batman09 said:
lonestar,
so I set my initial timing to 8*like you said and I have water or someting pouring(not really pouring kinda spraying) out of my tail pipes?/What is this?It kinda sounded better at 14*.I need some input here.This is driving me crazy!BM [/B]
Is there any smoke to go with it?
I shall get back with you tomorrow as I have to crash.
These 15 hr days suck.
If I can jump in and throw out the "f" word (ford), I would like to understand this a little better.
Be patient, I am gonna throw out a scenario you let me know whats incorrect. This is a truck application, no towing of any kind, 351w, 2wd, no emissions....the ignition is stock reman duraspark II using a GM four pin module.
Right now, I am using ported vacuum, with 8 BTDC initial. At idle I have zero vacuum, and zero advance, the second I crack the throttle it goes to 17-18hg and the vacuum advances the timing fully (correct?), as the rpms increase - the vacuum decreases- at the same time the mechanical is increasing, ideally so it balances out and the timing stays advanced.
Lets say I choose to run manifold vacuum, I connect the vacuum advance directly to the manifold, right off the bat the engine should increase in rpms at idle (correct?). So I adjust the rpms back down to 650, then put a timing light on it and with the engine running-manifold vacuum connected to the vacuum canister, I should adjust the hex screw inside the canister until I get a reading of around 20 BTDC at 650rpms, correct? Then I should make sure that at around 3000 rpm the mechanical advance is showing a total of 32+/- correct?
Thanks
Ported vacuum will increase to max with venturi draw. It will not decrease.
That sounds about right. Of course I am about dead and in need of sleep.
Thanks
1 - 15 of 15 Posts
