We would need the exact carburetor by number. Prior to SMOG requirements say up 1964 or 65 pretty much all vacuum advance would be full manifold vacuum from a carburetor port. From the mid sixties on a timed port was added and it what the OEMs used to delay the onset of advance till the engine speed moved above idle.
It really turns out from the hotrodders stand point that this gives us another toy to play with in relation to cam and compression selections that deviate from those of the factory. It’s really something that along with the base set timing you can play with to see if one offers any tuning advantages over the other. I wouldn’t attach a rule that says one is specifically better than another.
The big difference is with full time vacuum you get the maximum advance available from the system as soon as the engine fires, if your running a lot of compression but not a lot of cam duration this can help getting the engine started by not running so much base advance then allow the vacuum to fill in the best idle advance from the system. This eases the load on the starter without having to wire an ignition delay switch. If your running a lot of cam you cam where idle vacuum is low you could connect to the timed port while putting all the idle advance in the base. In this situation the manifold vacuum will peak upward as the throttle opens and the RPM starts to increase. This can allow a slight delay in the centrifugal so that it doesn't over advance the upper RPMs but provides good advance at part throttle cruise.
Basically either vacuum connection direct or ported once the throttle exposes the port will function the same.
For a mild engine with low compression and mild camming if idle SMOG is not a concern then a moderate amount of base and full time vacuum will provide a smoother idle. If you have to pass an idle emissions check and the vehicle does not use a 3 way converter, then you want to stay with less base and timed port vacuum advance to hold the NOx numbers down.
Otherwise this is an exercise to see what the engine likes best based on your vehicle, the terrain and weather where you live.
