this may be a silly question but it still needs some answering... How can i test the entire vacuum system in my car. the doorlocks have never worked since i got the car, and i'm not sure if the rear vent works either... does the campbells soup can have something to do with the vacuum system on the inside of my car? (its a 64 ford thunderbird) i'd like to start at the "front of the car" test the first item make sure its working, then test the 2nd item (the distribution block i think) then the 3rd (the switches for the 3 things (front door locks, vent, and trunk lock i believe is also vacuum (but its line is bundled up in the trunk and not hooked up) and then finally the actuators and hoses... just to make sure everything is good.. my dashboard is out right now so its the best time to replace things like hoses if that is the problem. if it is the vacuum hoses would i just pick up vacuum line in bulk and cut it to size... if i do this where would i buy it from? then if it is the actuators, can i plug the lines off until i can get some new ones brought up to canada? how much vacuum should i be getting through out the inside of the car? my repair manual doesn't have any of these questions answered
i don't want to just aimlessly buy parts just to buy parts, and replace them. i want to find the broken things and replace them and preferably only them
again thank you for all the knowledge you guys can give me
Mike
Mike
