I've ajusted a lot of valves on small chevies but have never tried this . I've seen this demonstrated on certain sites . I wonder how many of you motor heads have done it this way ? You can start anywhere the motor is setting . Have all rockers loose . Test all 16 push rods and adjust the play out of all loose ones , rotate 90 degrees and repeat , do this 90 degrees at a time until you have rotated the crank twice . Then tighten down all 1/2 to one turn and you are done . This guy swears this works on all SBC's. What's your thoughts ? I've been told racers do this all the time .
Bob
Bob
