Good advice on the "up and down" pushrod method, rather than the "spinning" method. I found out the hard way thta the up and down method is far more accurate.
Before you do your 1/4 to 1/2 turn, you want the lifter to have no preload, but be right on the verge of being preloaded. The problem with the spinning method is you can very easily have the lifter partially preloaded, and still spin the pushrod quite easily. So unless you have a lot of experience and great feel, you can easily make the valve too tight. And all the lifters can feel and preload a bit differently, so you can have them adjusted all over the place.
With the up and down method, there is basically no chance of midadjusting, and you don't have to have any "feel" or experience at all. It is VERY obvious when the lifter stops moving up and down and you are at "0" lash.
The method described in the post above will work great, but involves a lot of turning of the engine. Not a problem when the engine is on a stand, but when it's in the car, I found a great website that described a way where you only have to turn the engine once! You find TDC compression for Cyl 1, then adjust half the valves (he described exactly which ones). Then turn the crank 360 degrees and adjust the other half.
I used that method, along with the "up and down" method, and was finally able to get my valves adjusted spot on, after trying all the other different ways (engine on and engine off) without being able to get them quite right.
