any of you guys ever use the valve covers with the 2 tubes on one side with the clamp on breathers... and bare on the other valve cover??? are they good on a street motor or should you use a pcv style valve covers???
Canadian Charlie said:What about valve covers that have no holes for breathers, can they be used on the street? I really like those Dart aluminum ones
xntrik said:Remember seeing any "old" 50s-60s engines that had a oil filler neck on the intake manifold? They usually had a "road draft tube" and and after '62 a pcv to pull the blow-by out of the crankcase.
boobert said:I've got a 396 in my 67 Nova it has 1 breather on each side no pcv my problem is the blow by is causing oil to come out of the breathers on to my covers. My motor has about 800 miles on it roller rockers, roller cam etc. Probably around 550 HP any recommendations on how to eliminate the oil seepage.
