I put on one of my Comp Cams roller rockers (1412) to check the valve geometry. Before I pulled the original rocker I checked to see how much pressure there was on the pushrod. There was no up and down play but it turned with only slight resistance. I have never had any lifter noise. If I turn the nut down less than an eight of a turn more it would be too tight to turn. I checked some of the other valves and they were the same. If I do as the manual says and turn down the valves with a full turn after zero lash I think they will be too tight. I ran the truck for only a short while before the test but I think it was long enough to match sure the lifters were pumped up. It takes a long time to get it up to operating temp while idling. I had not run the truck for a week before then. This is a stock 72 350 block and heads.
BTW the geometry check showed the touch points started at the center of the valve and extending out to the exhaust side about 1/16”. How much shorter of a pushrod would I need to get it in the middle?
