possom83 said:
Hey Ya'll, I just bought a 1975 Chevy Cheyenne it was an orig. 454 truck but someone pulled it and put in a late model 305 stocker. My problem is this when i set the timing the valves rattle under a pull well they rattle pretty much anywhere you set the timing. It is a center bolt valve cover engine. A friend of mine said the cams are different but i dont believe that i read on 3rdgen.com that the HEI dist. are different on the early and late model engines. ohh and im guessing it was TBI engine they changed to carb. I need to know how i can tell the difference in the Dist. or do i need to run the #'s on the engines any help would be appreciated. Thanks
I guessing you mean it pings or detonates under load rather than having noise from the valve train????
What a down trade 454 for a 305, this means the 305 has got to work a lot harder than the 454 did for the same road speed.
If the 305 was originally an injected engine that was converted to a carb, then the distributor also needs to be back dated to a pre-electronic fuel injection HEI because the EFI distributor gets its advance from a computer you don't have. An old fashion coil in cap HEI with a mechanical and vacuum advance will be proper. You need to be careful with the distributor gear as well, if the 305 has a roller cam, then the gear on the distributor needs to be a factory Melonized gear, the gear an old HEI used against a flat tappet cam will wear very quckly when run against a roller cam. Check the block casting number 10243878, 14093627, or 14103058 are roller blocks.
Then of course the engine will have to be tuned, which also includes the carb.
