Im currently in the process of building a 302 for my 72 Comet. The motor is running with the valve lash set at 20 on both intake and exhaust; All eight cylinders. It runs OK, but I know the lash is'nt set right. The cam specs I have are as follows; .491 int .512 ex 108* lobe separation and duration at .050". It is set at 2* advanced. It has 289 heads, the ones with the heart shaped combustion chamber, 1.6:1 ratio roller rockers with 289 push rods. Also, the timing is a little off. Every once and a while it will back fire through the carb. It is set at 10* advanced. Any help anyone could give me I would greatly appreciate.
