Hi Guys,
Much against my own desires I followed the advice here and got myself some AFR enforcer heads instead of the ( and I quote) paperweight original iron heads .
I already had VS380 valve springs from melling for my cam together with valves etc etc.
I have aluminium heads now, so I will need something steelt to prevent tearing up the valve spring seat.
My question is: can I use just a 15 thou shim, 1.55" diameter that fits snuggly in the 1.55" valve spring seat on the head?
Or do I need to find a valve spring cup/locator to also locate the spring on the bottom? This would give me a perfect installed height.
The VS380 springs are a 1.22-1.23" OD spring with damper.
Thanks in advance!
Thanks in advance!
