Hey guys, Need your help on this one big time
Ok Ill start you all from the beginning. 4 years ago I began to re-build my 69 Ford 302 for my Mercury. Had the block completely checked out by a machine shop. Bought everything brand new for the Internals. Installed a Comp cam kit which was the Cam, Lifters, Magnum Pushrods and Roller tip 1.6 Rockers with the allen key Locks in the center. Engine ran great for a year. I moved to Arizona to go to Automotive Tech school. While there I came across a Crack Head who worked at a parts store and would give me parts for next to nothing as long as I put the money in his pocket instead of the Register
So I went crazy and upgrade from the 289 Performer Intake to the Air Gap and a Speed Demon Carb among other parts. Because I was doing the swap in my Apartment complex and wasnt allowed to work on cars in the carport I rushed the job and didnt seal off the coolant ports on the back of the intake very well. Inevitably coolant leaked into the lifter valley and before I knew it I had flattened the cam.
So here I am 4 years later back in california. I ripped the motor out and stripped it down. The cam was flat and the lifters were gonners, the oil pump was gone and the bearings had a little wear but actually looked ok. I think I caught it just in time. I sent the block back to the machine shop and they went through it and everything checked out ok. So totally cleaned up and ready to go I replaced all the bearings the cam and lifters, I stuck with the same pushrods and Rockers since they looked ok. This time around because I am on a budget, ( Married with children now hehe ) I installed a Performance Federal Mogul cam and Lifters. I also put on a double roller timing chain and retarded the cam.
Everything during the build went great, engine went in in a matter of days and besides a few ignition problems I had the engine running no problem. Now heres my problem. The engine is noisy as hell. Im getting great oil pressure all throughout the engine and its running fine. I use the Comp Cams recommended procedure of adjusting the rockers but it seems its just not working out. No matter what after a few revolutions of the engine the rocker seem considerably loose and it looks like the rockers arent hitting the Valves straight on their heads. Im stumped. I dont know what I did wrong or whats going on. If anyone can throw a few Ideas at me I would most appreciate it.
Sorry this is kinda a long story but I wanna lay down all the facts so hopefully someone can spot my mistakes.
Thanks ahead of time for any help or suggestions.
Buck
Buck
