1 - 2 of 2 Posts
I have a 1970 Chevy Nova, 350 CU IN 4 speed. The car starts to vibrate when you hit about 60 MPH. Nothing real bad but enough to bug you. It does not go away or get worse by going faster. I have put on brand new tires, and a new drive shaft. These two items did help but did not eliminate the problem. also if I am going over 60 and push in the clutch it does not cut down on the vibration so I don't think it is in the engine. Any Thoughts??
Thank you
Rick
Lost in the 60's
Welcome to Hotrodders........This is the Introduction forum so you should have posted your question probably in the Suspension forum....OK Have you thought about a wheel that is warped? Or maybe a loose wheel bearing, or a wheel bearing just starting to go bad. Just some ideas to think about and check out. :welcome:
1 - 2 of 2 Posts
