If your top is cracked or torn it is forming pockets for rust and corrosion as we read this note. The worst tops for rotten tops are the padded ones. Just cut the material with a boxcutter around the perimeter of the roof, and peel it like a skinned cat. Be prepared to be exposed to gross rust chips and possible holing especially at the lower rear quarters of the roof pillar at the top of the rear fenders. The top should be sanded, rust damage repaired, and then primed and finish painted (color is not important if you're replacing the vinyl, just use what you have in a good quality paint).
