1 - 6 of 6 Posts
Has anyone tried the volare on an early plymouth or does anyone have a better suggestion. thanks for any advise you have. I am returning to hotrodding after a short 30 year pause!
volare rear end
If the dimensions are similar in width , I would see no problem in it. I guess the big question is what engine your rear end was behind.
And what are you going to put in front of it now?
Volare clip
This clip has a pretty wide track,would not work well on a narrow car or truck. I have one under a 46Ford 1/2 ton, I may have to run negative offset wheels to make it look right. I had this same clip under another rod and it worked well.:thumbup: good luck
Discussion Starter #5
polare front clip in a 34 plymouth
Thanks for the replies to my foggy question. Can anyone give me the outer measurements for the polare clip - i wonder if it will fit between the 34 rails or if I have to splice them.
Volare clip
It should be wide enough,if not pretty close. Good idea to tack everthing and make sure it`s right before final weld. :thumbup:
1 - 6 of 6 Posts
