Preston Husker said:
Hey i have a 97 vortec 454, falls all over itself accelerating from stop, if u really get into the throttle when trying it it shakes and sputters but goes, chased mass airflow wasnt the cause. Bank 1 at 25% long fuel trim flushed injectors and have good gas. But i found that when looking at cylinder #1 advance its 25*. But when getting on the throttle it retards to as low as 2*. Unplugged knock sensors to eliminate the possibility of the vcm seeing detonation. The cmp retard offset is 1*. Running out of ideas appreciate any help. Comp cam that is supposed to run with stock factory injection. Honed cylinders and knurled pistons. Decked heads.003. Valve job.
The timing dropping back when you accelerate is normal, ignore it.What it is doing is dropping back so the engine doesnt knock under load as it is at low rpm. As rpm builds , so will timing advance.
Bank one adding 25 % enrichment is something.Sounds like a fuel starvation issue, like failing injector, or injectors on one side of motor. Dont overlook the fact it can be a vacuum leak, intake leak or any other source of unmetered air.
Unmetered air means air entering into engine that is not measure by the Mass air flow sensor, basically an air leak, which is not suppose to be.
CMP offset 1 degree... ignore it, thats normal -OK.
I would be checking for any air leaks, intake leaks,etc.
I would also check the fuel pressure. Those are very sensitive to even a few pounds difference from there specification.
Checking the injectors for spray and pattern will be a task, we can talk about that later. Check this stuff first.
didnt know anyone knurled pistons anymore, new ones are so cheap. Good luck.
