I have a 97 Vortec 5700 350 that I purchased out of a rolled Tahoe. I have the complete underhood wiring harness, computer and all accessories as it came out of the truck.
I have searched for information on how to make this swap simple into my 84 Suburban Hummer kit Truck. I was told that I needed about 65 psi in the fuel rails and power to four of the computer wires to make it work. After searching for several weeks at multiple sites I still have the same information I started with.
The closest information I have was in a post started in Aug 2003
http://hotrodders.com/showthread.php?s=&threadid=21533&highlight=96+vortec
Any help on this swap would be great.
I am assuming that I can use the stock fuel lines, but I will need to connect to the high pressure fuel rails with either a high pressure hose, or one of the quick disconnect high pressure fittings.
The original truck was a Diesel and had a rusty tank. I am replacing the fuel tank with a newer tank, but believe I will need to purchase an in tank fuel pump that puts out enough pressure to make the vortec happy.
This would take care of the fuel issues. The only other item is how to connect the wiring into the vortec harness. Since I am building a kit, the original suburban harness was discarded and is being replaced with a painless wiring fuse panel. This is basically a modern day street rod build. Has someone performed this swap, or have access to what wires need power on the Vortec underhood harness?
Thanks in advance for all of your assistance.
