I have a 350 with the vortec heads with a comp cams 480 lift cam, i installed heavier springs, have the comp hydrolic lifters, have question about the rocker. I bought the self aligning rocker the heads required but will they bind on the valve when they close?
Premium Member
Think its probably the spring that's the problem. Stock vortec heads require a bunch of work to go beyond .450 lift without springbind. Do a search, this topic has been covered to death, and you'll get your info quicker too!
K:thumbup:
Vortec Heads
Hey Metalmulisha3x,
I recently took a pair of Vortecs to the shop. They did a valve job and also ground down the valve guide boss in order to fit the heavier Z-28 springs on. I also plan on running the Comp Cams Xtreme Energy 262. Is this what you have? Plan on getting Edelbrock RPM Air-Gap Intake and a decent set of headers. I'm also running flat-top pistons which should put compression around 10.3:1 which should be able to run on 91, I hope. Should be a decent combination. As far as rockers go, I am using the original ones that the heads came with. They should work as far as I have been informed. Anyway, still have to buy the intake, cam, gasket kit, and headers. It's going in a pickup. Just curious to see how your combination runs since it is similar to mine. Any HP and torque estimates? Let me know. Thankx.
