They'll fit if your motor is a Gen I motor with conventional cooling system and not an LT1 Gen II motor. I have no idea how much you would gain from this head swap though, because I know little or nothing about EFI systems.I have a 1995 TBI 5.7 truck engine vin K will1996 vortec heads work on this engine ?
To keep the TBI EFI system, you will need to use a Vortec-specific TBI intake (shown below); earlier intakes have a different bolt patterns and will not bolt up to the Vortec heads and the ports don't match even if they did.I have a 1995 TBI 5.7 truck engine vin K will1996 vortec heads work on this engine ?
They will bolt on but require a Vortec to TBI intake. This will not have EGR ported from an exhaust crossover as it is not cast into the Vortec head. EGR requires external plumbing as was done on the 1996 up Vortec truck engines.I have a 1995 TBI 5.7 truck engine vin K will1996 vortec heads work on this engine ?
In that case you're better off leaving it as original. Unless you increase the displacement anything you do to the heads or cam will reduce bottom end torque, push the torque peak an horsepower to higher numbers but also they will be at higher RPMs than what the current LO5 peaks at. This will drive you to stiffer final gearing to restore power at cruise back to where it was with the swirl port heads.I,m after low in torque. I tow a 30 hp tractor with a half ton truck
There are 2 Swirl Port heads on the 350 engines the casting ending in 191 is 76 ish ccs the one ending in 193 is 64 ccs... The Vortec heads will help low end torque (1500-3500 RPMs) some if they offer a change from 76cc chambers to 64cc chambers... but I don't recall if the swirl port heads are 76cc or not... just remember the swirl ramps blocking the intake port flow...
No I talking head to head comparison on an otherwise idential engine or as much as it can be given the intake also needs to change in-so-far as bolt pattern is concerned so while it's the same intake model i.e. Edlebrock Performer RPM for example it still is not the same piece of equipment from one test head type to the other... That may be because they always increase the cam size as well...
