As is usual, I had something pushing me to finish a post (yes, I'm married)......I didn't get through with my thoughts, so I'll try to finish it up here..
Back to port flow......If you study Fluid Dynamics, you will learn that the lion's share of flow goes right down the middle of the vessel....or tube, so grinding on the surface of the vessel will do little or no good if you are not increasing the inside diameter of the tube. Smoothing the intake walls will only allow fuel to puddle when flow slows down on a larger diameter section of the tube or if the flow encounters a turn in the tube. Most engineers would probably agree that the surface of a port or tube can be as rough as a woman's fingernail file and not make one iota of difference in the amount of flow that will make it through the port. You can see that most of the flow goes right down the middle by standing on the bank of a stream or small river and looking out at the middle of the stream bed. The fastest flow and the resultant lion's share of the water going downstream is in the middle. Look at the banks of the stream. There is little to no movement where the water meets the land. This is the same way it is in a head and manifold port.
Speaking of manifolds, let's visit the science on them briefly. Realistically, a STREET MOTOR will want good, strong manifold and head flow from about 1,500 to about 5,000 rpm's. If your tach is above 5,000, you need to grab another gear and get back into the power-producing rev range of the cam (you DID install a STREET cam, didn't you?) Just so you and the rest of these fellows and gals reading this post, any cam you slide into the motor will have a power range of about 3,500 rpm's. It will not have a power range of idle to 6,500 rpm's, or even idle to 6,000, like a number of camshaft manufacturers would have you to believe (JUST SO THEY CAN SELL MORE CAMSHAFTS). Depending on the purpose of the cam, it will have a range of 3,500 rpm's, like 600 to 4,100 RPM's or like 1,000 to 4,500 RPM's or like 1,500 to 5,000 RPM's or like 2,000 to 5,500 RPM's or like 2,500 to 6,000 RPM's or like 3,000 to 6,500 RPM's or like 3,500 to 7,000 RPM's......or whatever.
Anyway......the best STREET intake manifold, where you need power from 1,500 to 5,000 RPM's, will be a long-runner, high-rise, dual-plane manifold mounting a single 4-barrel carburetor using vacuum-operated secondaries. Linkage-operated secondaries, also known as Double Pumpers, can be used effectively on the street if you are using an auto trans with a loose torque converter that will allow the motor to rev to at least 3,000 rpm's. This will prevent bogging from allowing the motor to see too much manifold at low rpm's. You can use a Double Pumper with a stick-shift transmission also, if you have a numerically high enough gear. You would not, for instance, use a Double Pumper with a manual box and a 3.08 rear gear and still expect the combination to work well.
Back in 1967, Chevrolet Motor Division had plans for producing a 5-liter V8 that could compete in National racing venues. That year, they introduced a brand new car that would fit the bill perfectly, a Camaro with a 302 cubic inch V8 that would fit nicely into the 5-liter requirement. They also needed a different intake manifold that would flow more air than the manifolds that were currently available off the shelf at Chevrolet, so they contracted with Winters Foundry to cast up some new aluminum intake manifolds that would pass a ton of air at higher rpm's. The manifolds were cast in a high-rise, dual-plane, single 4-barrel design and proved very quickly to be just the ticket that was needed. Well, it didn't take long for hot rodders to figure out that they needed one of these new Winters designs on their trusty street beast small block Chevy. Aftermarket manufacturers jumped on the bandwagon and began casting up the design too. Edelbrock made the Performer RPM 7101, Weiand made the Stealth 8016 and Holley cast up the best of the lot with their Street Dominator 300-36. Dyno tests have proven over and over that any of these manifolds, but particularly the Holley unit, can make more hp and torque on a street motor than any other design. If I were building a street motor today, I would seek out an offering of one of these on ebay or other used parts venue. Do not be fooled into buying one of the new "Air Gap" designs for the street. It is a RACE manifold, not a STREET manifold.
Nearly forgot to mention torque converters. You can buy a torque converter that will stall anywhere in the rpm range that you want it to, but most fellows will coordinate it with the power range of the camshaft, tailoring the low end of converter range with the low end of the cam's range, plus a few hundred rpm's. For instance, if your cam starts making power at 2,000, then you might want your converter to hook up at maybe 2500, about 500 rpm's above the low end of the cam. Don't be afraid to use some gear on the street.....3.73 or numerically higher will work fine.
