Vortec head timing
The GM Vortec heads generally don't like as much total timing as the older style heads did, but the usually run better with a little more initial timing. From what we've seen about 4 degrees less total advance is a safe starting point, and 2 or 3 more initial.
You'll need to recurve your distributor to get this set properly.
