this is happening in my 1995 suburban
When I hook up the negative battery cable my warning lights come on key off.
when i start the engine it does not turn off unless i remove coil wire.
I replaced the ignition switch and ended up with the same results
I just put in a new engine and all wires look fine what could cause this?
